When you right click on a track you can select "Add to Search DB" is this available in a VDJ script, I couldn't seem to find anything that seemed to match.
My use case: When I add new music to Virtual DJ I do it by dragging it from the Windows to the VDJ playlist I want it in. I have autoSearchDB off so I don't pollute my search index with extra files as I'm browsing directories in Virtual DJ so the files I drag in aren't added to the search DB automatically.
What I wanted to do is when I set my first cue point on a track it would "Add to Search DB".
Is there a better way?
geposted Fri 29 Sep 23 @ 10:46 pm
