If I set 50/50 cue/mix on the controller, I can hear that the signal from the PFL is much lower. I've tried everything in the settings but it doesn't help ,unless I need to change something in the mapping of the S8 tractor, but unfortunately I don't know much about mapping . I would very much like to ask for help if anyone had a similar situation
geposted Sat 30 Sep 23 @ 10:36 am
did you try the HeadphoneGain setting?
you can search it out in options
geposted Sat 30 Sep 23 @ 1:09 pm
yes, it didn't help
geposted Sat 30 Sep 23 @ 4:58 pm
