Topic: POI's Portable?
Hi,
Just wondering if POI's are portable? Meaning if I use a different DJ Software will the POI's I have created in VDJ still be there in the other software? Or if not automatically is there a way to make it happen?
geposted Sat 07 Oct 23 @ 1:16 am
hotcues, saved loops, there are database converter apps out there to migrate.
action poi, no other software does that kind of thing.
geposted Sat 07 Oct 23 @ 2:13 am
Ok, thanks mate, I'll do a google search see what I can find.
geposted Sat 07 Oct 23 @ 9:38 pm
