Hi,
FOR: PIONEER SX2
Is there a way I can change the Pad Mode "ROLL" option to "STEMS"? I only use the Pad Mode for "HOTCUE" and I'd like to switch between "HOTCUE" and to "STEMS" using those buttons instead of having to go to my Macbook and change it there.
FOR: PIONEER SX2
geposted Mon 09 Oct 23 @ 12:32 pm
geposted Mon 09 Oct 23 @ 1:17 pm
djdad wrote :
Holy smokes, is it that easy? Thank you if it is! I'll try it when I get home later tonight!
geposted Mon 09 Oct 23 @ 3:40 pm
I dont get it..
How do I replace the "Roll" button to "Stem" ?
geposted Mon 09 Oct 23 @ 5:04 pm
freppa wrote :
I dont get it..
It worked dude. So I use the first bank for my "hotcues" and then when I want to use "stems", I just hit the "roll" button and instead of getting "roll" effects (whatever that is) the buttons are now used for "stems"; vocal, instrument, kick, hi hat, etc. after I blend in the song I hit "hotcues" again to go back to cueing the next song.
geposted Tue 10 Oct 23 @ 2:38 pm
Still dont get it how to make the change of the default Roll button.
I need a Tutorial :(
geposted Tue 10 Oct 23 @ 4:26 pm
In the pads section on the skin, open the drop-down, open the sub-menu for page 2: roll for your controller, select stems.
geposted Tue 10 Oct 23 @ 4:45 pm
Which controller ?
Isn't the manual link above offer all info ?
Watch this too.. https://youtu.be/aFrtCLo3sgY?t=84
If your controller is connected, it's just a click on the Pad page drop down menu
geposted Tue 10 Oct 23 @ 4:47 pm
Still dont work for me, it doesnt change when I use the pages edits?
Using Pioneer DDJ SX2
geposted Wed 11 Oct 23 @ 6:27 pm
and default/factory Mapping ?
Do you get the menu that shows the assigned Pad pages ?
geposted Wed 11 Oct 23 @ 6:53 pm
Yes, I see them (picture)
The problem is to save it to for example "roll" button.
Stem wont stay as default after the change, dont know if it is anything with the mapping that im missing?
geposted Thu 12 Oct 23 @ 3:44 pm
This is the picture..
It doesnt work to jump to stems with the slicer button on the controler.
Should this work right away when I have changed it ?
I can jump between all other padpages hotcue, looproll and sampler on the controler.
geposted Thu 19 Oct 23 @ 5:09 pm
