Hi,
Am I the only one experiencing VDJ crashing when using scratch dna in a loop?
Not the first time, but after a few tries.
This is what I call DNA scratching with a pad:
effect_active "scratch dna" off & scratch_dna 'CADA.EAEA'
Regards,
David
v2023 b7692
Hercules DJCONTROL INPULSE 500 custom mapper
Novation Launchpas Pro custom mapper
Regards,
David
v2023 b7692
geposted Sun 22 Oct 23 @ 8:33 am
not seeing issue here, I used the scratch longer than end of loop trick to get repeated scratches and it ran for 20 minutes until I checked back on it.
geposted Sun 22 Oct 23 @ 9:49 am
Did you try to press scratch dna a few time during the loop?
geposted Sun 22 Oct 23 @ 10:07 am
for the first couple of minutes yes.
geposted Sun 22 Oct 23 @ 10:16 am
The freeze happens when :
Deck B is master deck playing.
Deck A is beatlocked, stopped and pre-looped on 4 bars....
When using scratch DNA to start the DECK A track > Freeze.
geposted Sun 22 Oct 23 @ 10:22 am
https://youtu.be/4R0nw42tILM
Don't forget to beatlock the deck that starts with the loop by scratch DNA.
geposted Sun 22 Oct 23 @ 10:53 am
The bug doesn't happen when Deck A & Deck B are inverted
Deck A is master deck playing.
Deck B is beatlocked, stopped and pre-looped on 4 bars....
When using scratch DNA to start the DECK B track > OK !
geposted Sun 22 Oct 23 @ 11:02 am
No need to loop!
The bug happens from cold start when using scratch DNA to start the track on deck A when deck B or C or D is master and deck A is beatlocked.
geposted Sun 22 Oct 23 @ 11:08 am
Can't reproduce here.
The script on your pad is as you metioned?
(Since in the video the deck returns to cue 1, but I don't really see why that would happen with only scratch effect)
geposted Sun 22 Oct 23 @ 11:17 am
Yes the scipt behind the pad is like this.
geposted Sun 22 Oct 23 @ 11:26 am
Here is a new simplified video...
On this video, I use the native scratch pad...
https://youtu.be/FVMz7WwB5lU
Don't forget to beatlock deck A before start, deck B is master and try to start with scratch DNA...
geposted Sun 22 Oct 23 @ 11:34 am
The freeze bug has been reproduced on my former laptop with VDJ v2023 b7360 without any custom mapper. On this version (b7360), it happens also if Deck A is master and Deck B is beatlocked and Deck B is started with a scratch DNA pad.
On the last version it seems to happen only when Deck A is beatlocked and one of the other Decks is master.
geposted Sun 22 Oct 23 @ 8:26 pm
https://youtu.be/DvSarxC7kaM
VDJ 2023 fresh install v2023 b7692
Deck B master
Deck A beatlocked
VDJ freeze when the track is started with scratch DNA.
Deck B master
Deck A beatlocked
geposted Sun 22 Oct 23 @ 9:55 pm
i've reported bugs before then rebooted my system and they are magically gone ... you never know :-)
geposted Sun 22 Oct 23 @ 11:23 pm
Hello Wickedmix, I restarted several times and tried on 2 different computers: same bug, systematic.
geposted Sun 22 Oct 23 @ 11:38 pm
Try early access build 7735 as it appears to have a fix.
geposted Mon 23 Oct 23 @ 8:26 am
Early Access build 7735 have fixed this problem.
Thanks to the team of developpers and to Kradcliffe ;)
geposted Mon 23 Oct 23 @ 9:05 am
