Hey Folks,
I want to buy the X1 Mk3, is there any chance to run it with VDJ-8 (Infinity)
I don't mind if I have to program the mapping myself.
But how has it to be done?
Do You think we'll see an official mapping support soon?
Greets
Fox Redfield
Greets
Fox Redfield
geposted Fri 27 Oct 23 @ 7:07 am
Simple mapping should be easy.
Full support is on our plans, but we cannot provide an ETA.
geposted Fri 27 Oct 23 @ 9:36 am
Nice to hear, bit before will it work in any way, or not?
geposted Fri 27 Oct 23 @ 10:09 am
I bought it and it´s working great with the stock template!
There are only two little change i would appreciate:
1. Using mixer in STEMS mode it would be more logical to invert the led of the buttons.
Example:
I am playing a song and all stems are ON the buttons are dimmed.
The buttons are working like a kill switch.
When i press HIHAT the HIHAT is killed but the light turns from dimmed to 100%.
Personally i think it would be more logical to have all light on when all STEMS are on and dim them after pressing the KILL Switch?
2. STEMS color = led color (e.g. HIHAT Yellow, Button Yellow)
Example:
geposted Tue 11 Jun 24 @ 9:28 am
I just got the X1 mk3 as well and it does work great with stems, and also effects can be triggered easily. The looping also works great.
Has anyone added any other functionality?
geposted Thu 20 Jun 24 @ 2:39 pm
Such as ?
What do you think is missing ?
geposted Fri 21 Jun 24 @ 2:05 pm
Is it now fully supported?
geposted Mon 26 Aug 24 @ 5:28 pm
geposted Mon 26 Aug 24 @ 5:51 pm
