Topic: Pioneer DDJ-REV7
I do everything to make work the left jog wheeler but i cant make it work my Pioneer DDJ-REV7 any help please.
geposted Sat 04 Nov 23 @ 11:47 pm
What issue exactly do you have ?
It would help if you could describe your issue as detailed as possible
Rudy I know exactly what your talking about BRO!. You need an answer..
STEP 1 - DID YOU Install & RUN The Pioneer Rev-7 Audio Driver? If Not You will need it 1st
Before you run VDJ.
1) CREATE & SAVE a New REV-7 (Custom)
2) GO INTO YOUR MAPPING, and Look for ONINIT
3) SET YOUR SCRIPT FOR ONINIT (When Loaded Do This or That)
What does all this has to do with "left jog wheel not working" ?
If the OP means that the platter doesn't rotate (but the deck plays sound) then most likely he has just turned off vinyl mode for that deck.
you hit the jog wheel mapping something you didn’t see before you hit save just copy the factory and use it to your mapping...I did that lol
I am having this issue also!
My Rev 7 works well other than the left platter not spinning but it plays audio when a track is loaded there. But the motor doesn't want to even spin.
BUT!
If i use the scratch mode with the pre loaded samples built into the controller itself, the platter spins! works perfectly only in that mode! It really makes me believe that there's something going on with virtual DJ or The Mapping alone. Someone Please Help!
SO I FIXED IT!!! I had to go into settings and search vinyl mode and select (PER DECKS) And then select both boxes for left and right Decks..... So Simple! Makes me Happy and Mad at the same time! lol
It's right there!!
Hello Guys, same issue here but on the right deck, i tried the trick with ''vinyl mode per deck'' ,worked for 1-2 weeks,now it started again. Also,while i play i switch toper deck....somehow it jumps to the ''yes'' setting after few minutes.
any advices?
Thank you in advance !
Sorry ,still me here,i accidentally logged in with my gmail account.
Hello Guys, same issue here but on the right deck, i tried the trick with ''vinyl mode per deck'' ,worked for 1-2 weeks,now it started again. Also,while i play i switch to ''per deck''....somehow it jumps to the ''yes'' setting after few minutes.
any advices?
