Hi all, transfer my files from Macbook pro M2 to new Macbock pro M3 Pro processor, any tips of that is wrong?
//Patrik
//Patrik
geposted Tue 07 Nov 23 @ 2:21 pm
Did you copy everything over from your old macbook with time machine or whatever it's called as that can cause errors.
geposted Tue 07 Nov 23 @ 2:31 pm
i used the transfer from old mac - to new mac option, will try to do backup restore
geposted Tue 07 Nov 23 @ 2:37 pm
No the same error , Is the new M3 pro processor supported in VDJ?
geposted Tue 07 Nov 23 @ 2:59 pm
-LOG REPORT
- 2023/11/07 - 15:57 (7759)
[15:57:41] Stems engine GPU failed. m1 error Unable to load model: file:///Applications/VirtualDJ.app/Contents/Resources/model1.mlmodelc/. Compile the model with Xcode or `MLModel.compileModel(at:)`.
[15:57:41] Fallback to no stems separation (GPU not available)
--- 2023/11/07 - 16:31 (7759)
[16:31:36] Stems engine GPU failed. m1 error Unable to load model: file:///Applications/VirtualDJ.app/Contents/Resources/model1.mlmodelc/. Compile the model with Xcode or `MLModel.compileModel(at:)`.
[16:31:36] Fallback to no stems separation (GPU not available)
--- 2023/11/07 - 17:15 (7759)
[17:15:44] Stems engine GPU failed. m1 error Unable to load model: file:///Applications/VirtualDJ.app/Contents/Resources/model1.mlmodelc/. Compile the model with Xcode or `MLModel.compileModel(at:)`.
[17:15:44] Fallback to no stems separation (GPU not available)
geposted Tue 07 Nov 23 @ 4:18 pm
Using TimeMachine or iCloud to transfer things from one MAC to another is known to cause the Stems Engine Error.
So, wipe your new MAC clean (again) and just start from scratch without using TimeMachine or iCloud to transfer data and settings from the old MAC.
PS: The error actually comes from Apple's own encryption algorithm, and we don't know why.
geposted Tue 07 Nov 23 @ 9:31 pm
its working now :-)
geposted Wed 08 Nov 23 @ 11:08 am
Hi, I have the same problem: I migrated my system to an new M3 Mac and I am getting these Stem Engine Error Alerts. My problem: I definitely can't swipe my harddisk and begin from scratch, because of too big data, already in use. What else ideas or workarounds are known? 😨 Please, help me
geposted Sun 21 Apr 24 @ 9:56 pm
