Forum: German Forum
Topic: VideoSkin Minimalist UX 1
Hallo, wie kann ich die Farbe von Minimalist UX 1 komplett in Blau ändern?
Danke!
geposted Fri 10 Nov 23 @ 1:31 pm
geposted Sat 11 Nov 23 @ 7:34 am
Hallo,
der Skin bringt von Haus aus schon mehere Farbprofile und sogar Hintergründe mit. Leider ist das vom Ersteller schlecht (gar nicht) dokumentiert. siehe nächster Post ;)
Farben (Auszug aus der Skin.XML):
<!-- COLOR DEFINES -->
<define color="themecolor" value="white"/>
<define color="themecolor" value="#33adff" condition="var 'miniUXcolor' 1"/><!-- blue -->
<define color="themecolor" value="#66ff99" condition="var 'miniUXcolor' 2"/><!-- green -->
<define color="themecolor" value="#ff9933" condition="var 'miniUXcolor' 3"/><!-- orange -->
<define color="themecolor" value="#cfeb34" condition="var 'miniUXcolor' 4"/><!-- yellow -->
<define color="themecolor" value="#ff4dff" condition="var 'miniUXcolor' 5"/><!-- purple -->
<define color="themecolor" value="#ff3333" condition="var 'miniUXcolor' 6"/><!-- red -->
<define color="themecolor" value="#9966ff" condition="var 'miniUXcolor' 7"/><!-- purple -->
<define color="themecolor" value="black" condition="var 'miniUXcolor' 8"/>
<define color="solidcolor" value="white"/>
<define color="solidcolor" value="#33adff" condition="var 'miniUXcolor' 1"/>
<define color="solidcolor" value="#66ff99" condition="var 'miniUXcolor' 2"/>
<define color="solidcolor" value="#ff9933" condition="var 'miniUXcolor' 3"/>
<define color="solidcolor" value="#cfeb34" condition="var 'miniUXcolor' 4"/>
<define color="solidcolor" value="#ff4dff" condition="var 'miniUXcolor' 5"/>
<define color="solidcolor" value="#ff3333" condition="var 'miniUXcolor' 6"/>
<define color="solidcolor" value="#9966ff" condition="var 'miniUXcolor' 7"/>
<define color="solidcolor" value="black" condition="var 'miniUXcolor' 8"/>
<define color="solidcolor2" value="black"/>
<define color="solidcolor2" value="white" condition="var 'miniUXcolor' 8"/>
<define color="gradientcolor" value="black"/>
<define color="gradientcolor" value="white" condition="var 'miniUXcolor' 8"/>
Mit diesem Script auf einem Button kannst du die Farben durchschalen:
cycle miniUXcolor 9 & setting 'useVideoSkin' off & wait 30ms & setting 'useVideoSkin' on
cycle miniUXcolor 9 schaltet durch die Farben und setting 'useVideoSkin' off & wait 30ms & setting 'useVideoSkin' on dient dazu den Videoskin zu aktualisieren.
Wenn du z.B. blau direkt wählen möchtest kannst du diesen Script verwenden:
set miniUXcolor 1 & setting 'useVideoSkin' off & wait 30ms & setting 'useVideoSkin' on
Dann gibt es noch die Optionen des Hintergrundes:
Hintergrundart:
Transparent, Farbverlauf, Bild
Zum durchschalten diesen Script verwenden:
cycle miniUXbg 3 & setting 'useVideoSkin' off &  wait 30ms & setting 'useVideoSkin' on
Wenn du als Hintergrund "Bild" hast, können 3 verschiedene ausgewählt werden:
cycle miniUXimage 3 & setting 'useVideoSkin' off &  wait 30ms & setting 'useVideoSkin' on
geposted Sat 11 Nov 23 @ 8:43 am
geposted Sat 11 Nov 23 @ 8:55 am
Danke DennyYo Beats für die schelle Rückantwort. Mal schauen ob ich, als älterer Herr, das gebacken bekomme. :-)
geposted Sat 11 Nov 23 @ 10:26 am
Mit der Padseite ist ds kein Problem :) das ist ja alles vorbereitet.
geposted Sun 12 Nov 23 @ 5:42 am
