Good day,
When I try and log in with my Virtual DJ ID, it doesn't work. It says no servers are available.
I am however capable of login on your website.
So then I use my google details to log in and then it says browser is not secure. I have switched between Firefox and Chrome and the same happens. All my other websites are running on HTTPS so the browser is on a secure setting.
Options?
Options?
geposted Wed 15 Nov 23 @ 4:32 am
Try this tool ...
For PC:
https://www.dropbox.com/s/karz2iau751rxmj/FixVirtualDJHosts.exe?dl=0
For Mac:
https://www.dropbox.com/s/nc837lqn2jnecgu/Fix%20VirtualDJ%20Hosts%20Mac.zip?dl=0
If the tool doesn't work, try to edit the hosts file manually and remove the virtualdj entries
https://support.rackspace.com/how-to/modify-your-hosts-file/
geposted Wed 15 Nov 23 @ 5:53 am
hello, i can't use the code that i received with controller anymore ?
geposted Thu 16 Nov 23 @ 11:09 pm
