Hi,
I found a Bug,
When i Change the Stems by using the Mixer section of my Prime4 i See one the Pads that is full Off but the eqs in the pro skin Show No changes Like before.
I found a Bug,
geposted Sat 18 Nov 23 @ 6:12 pm
Wrong Name in Thema because i wrote with my Smartphone.
I mean false optical Output for stem EQ.
But after i use the Pad to hard Cut Stems it works for the Stem EQ in the Skin.
geposted Sun 19 Nov 23 @ 8:40 am
