Topic: Setting On Blocks Skin 4 decks
I am using Blocks skin 4 deck vertical waves. Underneath the vertical waves to the left there is a dropdown box labeled master. When I select the effect I want, it gives me the selected effect on all four decks. Underneath the vertical waves to the right there is a drop drown box labeled Max FX. When I select the effect on that it does nothing on any deck. So, my question is what the heck is Max FX, what is it supposed to do and how does one get it to work!
geposted Thu 23 Nov 23 @ 7:49 pm
Thanks. Cleared it right up!
