How do I export a recorded mix and or automix playlist as a text file with timestamps so when I upload to Youtube I can ID the tracks at the correct time, I saw the solution once.
geposted Sun 26 Nov 23 @ 5:47 pm
Hello
Go to the vdj=> history folder
Tracklist file
Tracklist file
geposted Sun 26 Nov 23 @ 6:04 pm
set it to generate a cue file it will contain the times stamps your looking for
geposted Sun 26 Nov 23 @ 7:32 pm
Thanks sounds like what I am looking for as the normal .txt file dosent have the timestamps, How do I set it to generate a cue file?
geposted Mon 11 Dec 23 @ 12:37 pm
should be in the record section of options
geposted Mon 11 Dec 23 @ 1:52 pm
Awesome thanks, I found the setting!
geposted Tue 02 Jan 24 @ 12:54 pm
