Last night while playing at a gig, my FLX6 started to stutter for a couple of seconds. When this happened, the lights in the controller all lit up (dimly) and started flashing.
A couple of seconds later it stopped doing this and carried in as normal.
Any idea what could cause this?
I replayed the same track after the guests had left and it all worked perfectly, so it’s not the track.
I’m running windows 10 with automatic updates switched on for VDJ.
Apparently, a colleague has had the same issue with his FLX6.
geposted Sun 26 Nov 23 @ 6:57 pm
Looks like a temporary power/usb disconnection.
As a precaution measure, replace the USB cable
geposted Mon 27 Nov 23 @ 9:24 am
Thanks, I’ll give that a try. Hopefully it solves the problem.
geposted Mon 27 Nov 23 @ 6:01 pm
