Hi,
I would like to have more stems channels. Bass Kick Vocal Hihat Instru are cool, but we producers need more channels, 6 channels are minimum. I have splitted the stem channels into 2 categories:
Drums:
Kick - Perc - Hihat
Idea of the Track:
Bass - Channel1 - Channel2
(Bass - Synth1 - Synth2)
(Bass - Synth - Vocal)
(Bass - ... - ...)
Every channel should have own knob. 2 Midi controllers Xone K2 are the best option - 6 knobs pro deck ...
What do you think about it?
Drums:
Kick - Perc - Hihat
Idea of the Track:
(Bass - ... - ...)
geposted Tue 28 Nov 23 @ 8:13 pm
This feature is for Producers only - for people who make own stems files (not VDJ stems files). Original VDJ Stems can stay like BASS KICK VOCAL HIHAT INSTRU ...
geposted Tue 28 Nov 23 @ 8:16 pm
Too specialist to be considered for mass production, but nothing stopping you from having a skin that does what you want.
geposted Tue 28 Nov 23 @ 8:18 pm
The skin does not support to load a file with 6 stereochannels ...
geposted Tue 28 Nov 23 @ 8:24 pm
but you can have a 12 deck skin, a plugin can read a tag and load 5 other decks on load. My remix skin is 10, I've made 18 deck on earlier iterations.
If you want something outside the box, you have to think outside the box.
or you could engineer 2 * 5 stem tracks, 2 decks per side, 10 stereo channels per side
geposted Tue 28 Nov 23 @ 9:07 pm
This section is News Features and Wishes and for this Reason I think, that I can write, what I would like to have ...
geposted Tue 28 Nov 23 @ 9:16 pm
You can write it, and people can suggest solutions.
Bear in mind though that this is DJ software, not production software - and there are plenty of existing options out there for separating stems beyond what VDJ offers.
geposted Tue 28 Nov 23 @ 9:28 pm
VDJ is DJ software and some producers are DJs too!
I dont want to separate something. VDJ has own stems creator for producents already. And I dont think, that 1 more stem channel is something, was costs much time and money to implement it ...
geposted Tue 28 Nov 23 @ 10:06 pm
I dont need to separate someting, because I did it already in DAW...
geposted Tue 28 Nov 23 @ 10:08 pm
So put together what you can do now, make a stem track with 5 sources, then make another stem track with your other sources, then you just have to make loading one loads the other, and when you press play on deck 1 then deck 3 plays too.
I could do your wish today, it's not hard but it's too niche to be a dev thing, the devs do niche requests but it has to be either a small change or make sense for future development.
If you think it is a future development thing, get it made, if it's popular then it will become native code, if it's not popular then what do you care, you have your bespoke thing anyway.
geposted Tue 28 Nov 23 @ 10:33 pm
Now I am using the workaround with 2 stem files for 1 track. It works, but it is no a good solution ...
geposted Thu 30 Nov 23 @ 12:38 pm
Even world famous DJ/producer/remixer Francois Kevorkian is using this method to play two sets of four stems at the same time (although he uses Traktor).
https://www.youtube.com/playlist?list=PLCr4LSsJFk48tmNoKn-l7mgsB5XUd2Af9
geposted Thu 30 Nov 23 @ 1:02 pm
