Hello Supporties!
After I had my last update, ALL the available Skins for my Virtual DJ Infinity were flickering. When I move the mouse into the library or sidelist or anywhere else on the skin it immediately starts flickering. ALL my Graphic-Cards-Software is actualized and running perfectly on all the other software I have on my LapTop.
It is bothering me to run my gigs with this flickering.
What can I do to solve this problem? Step back to an older version of VDj?
If yes, then please send me a link!
Thank you very much for you help.
Regards Enzo
Regards Enzo
geposted Wed 29 Nov 23 @ 7:57 pm
turn setting experimentalSkinEngine off
geposted Wed 29 Nov 23 @ 8:00 pm
Thanks for that, just solved an issue I was having with the CBG lines flickering - no idea why experiment skin got turned on along the way, seemed to be with a recent update, but please to have found the cured to the issue was driving me mad!!
geposted Sat 02 Dec 23 @ 4:01 pm
