I noticed that the Beatjump pad page is mapped to shift + dbl click Roll (user mode 6) on my DJM S11 (I can't remember if it was default or not (the S11 manual doesn't seem to match what I see for the mixer and I think I made a couple pad changes).
With the Beatjump page mapped as said above, I cannot use the parameter buttons to go to the next/previous set of jump sizes. When I looked into into the mapping, it seems like the button isn't defined for User Pad Modes 5-8.
Is this a mapping issue or no?
geposted Thu 30 Nov 23 @ 4:00 am
Looks like they were indeed not mapped, will add.
If you modified your own mapper, you can add them easily yourself:
USER6_PARAM- to pad_param -1
USER6_PARAM+ to pad_param +1
(and you can do the same for the other USER*_PARAM you want to use)
geposted Thu 30 Nov 23 @ 12:00 pm
I can do that in the meantime. Thank you for taking a look/confirming.
geposted Thu 30 Nov 23 @ 1:30 pm
