Hey, I was wondering is there like a computer software out there that I can download for free or maybe even cheap that will help boost virtual DJ while I'm doing a recording or just mixing up music?
geposted Sun 03 Dec 23 @ 4:52 pm
What do ypu mean by "boost"?
geposted Sun 03 Dec 23 @ 5:11 pm
Unless you're using real time Stems separation, VirtualDJ is not heavy on resources and it will work absolutely fine with almost any PC from the last decade.
So, there's really no need to boost anything.
On the other hand, if you use real time stems then (in theory at least) you already have a powerful machine and there's no need to boost it. Just make sure you don't use any application that will put more stress on your GPU.
geposted Mon 04 Dec 23 @ 2:19 pm
