I found a skin I like but I don't know how to make it my default. Seems like a basic question but I'm stumped
geposted Wed 06 Dec 23 @ 7:42 pm
there should'nt be a need to make it the default...vdj will open with the skin last used...
geposted Wed 06 Dec 23 @ 10:39 pm
Nope, doesn't do that. It always reverts back to "Default - Pro". I like "Old - 2 Decks". I have been using that skin for at least 10 years without incident until the last software update.
geposted Thu 07 Dec 23 @ 5:10 am
Believe you may be looking for this skin:
https://virtualdj.com/plugins/index.html?addonid=81676
Need to Add, then it will be the skin that is used every session of VDJ.
https://virtualdj.com/forums/255449/addons/VirtualDJ_8_Old_Default.html?page=1
w this post:
w this post:
groovindj wrote :
For clarification, this is a copy of the skin that was previously embedded in VDJ, listed under Old - which has been removed in build 7805.
geposted Thu 07 Dec 23 @ 5:56 am
Yes that is the skin I want to use but I can find no way to add it in. Whatever I do, it is only temporary. When I close VDJ and then reopen it's gone. I have to be missing something!!
geposted Tue 12 Dec 23 @ 1:22 am
check vdj has write permissions
geposted Tue 12 Dec 23 @ 1:29 am
Oh dear, you're getting too technical. My old brain can't absorb all of this. Please tell me how to determine whether I have write permissions and how to change them if they are incorrect
geposted Tue 12 Dec 23 @ 8:05 pm
geposted Tue 12 Dec 23 @ 9:21 pm
This keeps coming up. How about an error message from the program that directs people to a page explaining how to fix?
geposted Wed 13 Dec 23 @ 12:14 am
your problem
geposted Wed 13 Dec 23 @ 12:41 am
What does that mean? I don’t have the issue I’m merely making a suggestion for an improvement that would reduce the times this question comes up in the forums.
geposted Wed 13 Dec 23 @ 12:58 am
All items are allowed. Didn't have to edit. All permissions were allowed. What's next? I don't want to keep this thread going. I just want to solve my problem
geposted Wed 13 Dec 23 @ 3:09 am
Okay Guys, what do I do next? I have all the permissions.
geposted Thu 14 Dec 23 @ 9:41 pm
