Hi all i am trying to write a script to crossfade to the other desk as Fast as I can and then to start the other desk
auto_crossfade 5ms ...
what do i put after this to have the other desk to play no matter what deck I am on ?
Just saw this
deck 1 masterdeck ? deck 1 stop & deck 2 play & crossfader 100% : deck 1 play & deck 2 stop & crossfader 0% & deck 1 select
Thanks DJDAD
Thanks
Just saw this
Thanks DJDAD
Thanks
geposted Fri 08 Dec 23 @ 9:32 pm
You can also do it a lot simpler mix_now, and just set it to be really fast
Like:
mix_now 33ms
I would probably prefer 1 beat of mix time, even for fast mixing:
mix_now 1bt
That also syncs the tracks
If you don't want that, you can use mix_now_nosync instead
So like:
mix_now_nosync 33ms
Like:
mix_now 33ms
mix_now 1bt
So like:
mix_now_nosync 33ms
geposted Sat 09 Dec 23 @ 1:15 pm
