Topic: DJ Ycee
My virtual di 8 keep freezing all the time
geposted Sat 09 Dec 23 @ 7:55 pm
then the first thing you should do is stop using out of date software, make sure your computer is capable of running the software the way it's supposed to, and if not then learn to adjust it so you can use it without too much difficulty.
go here to update:
virtualdj.com/download
