Hi all virtual DJ users and script writers,
I am looking for a solution to mimic some of the expensive controllers with a screen built in.
The reason for this is to still make use of my older analogue mixer with the flexibility to use an external screen.
An option would be to use the nice newer virtual DJ remote, but i lacks the normal control with buttons and isn`t synchrone with browsing through your file library.
I came across the blocks skin interface and i noticed its have an floating browser library. Would it also be possible to create an floating waveform display, so i can toggle on and external screen between a browser vieuw and the waveform view?
Greetings,
Marcel
Greetings,
Marcel
geposted Mon 11 Dec 23 @ 3:24 pm
geposted Mon 11 Dec 23 @ 8:07 pm
The skin works perfectly, but I would like to use some hardware control buttons for scrolling and selecting tracks in the browser. As the rotary push buttons works on controllers.
Is this possible set me way?
Gr Marcel
Gr Marcel
geposted Tue 12 Dec 23 @ 6:46 pm
I do skin edits but I ask for a couple of beers to repay the favour.
Or you can have a go yourself but I think it will be a steep learning curve
https://www.virtualdj.com/wiki/Skin%20SDK
geposted Tue 12 Dec 23 @ 7:36 pm
Possibly...
You could use the skin "Multi Touch".
Then "duplicate" the screen to a second monitor.
(as a test)
(as a test)
geposted Tue 12 Dec 23 @ 11:04 pm
