Topic: Has this been done yet? Serato style stem mapping
So I currently use Serato and while VDJ is superior in regards to clean separation. Serato has preconfigured mapping for the S11 on how stems can be used. The 4 pads from left to right are mapped as vocals, melody,, bass, and drums. While the bottom row is a secondary action on how stems can be triggered. From left to right , the 1st pad on the bottom will echo out the stem vocal with all the other stems being active , 2nd pad will echo out the drums, 3rd pad will trigger to disengage all stems minus vocals and trigger a motor brake.
Im curious if this has been done yet or if this is possible through VDJ’s scripting. More so that VDJ has wavform support outside of Serato for the S11
- Rod
geposted Fri 22 Dec 23 @ 9:06 pm
That looks very promising, thanks for the heads up
