Topic: Hercules inpulse 500 - controls jumping
Hi Everyone,
Just wondering of anyone has had a problem with a Hercules Impulse 500 controller gain and eq knob/s jumping when using them? The high eq and now the gain jumps from high to low on their own when I don't touch them thus making it hard to adjust the volume and also mix songs. I've tried reuploading vdj but it seems it's the controller.
Any advice would be appreciated before I get a new controller as it seems it will either cost a load to get it looked at or no one will touch it.
Thanks everyone in advance
Ben
geposted Sun 28 Jan 24 @ 5:20 pm
You can check if it's actually the controller sending unwanted midi commands
More info at the end of this video:
geposted Sun 28 Jan 24 @ 6:32 pm
vardavasPRO SubscriberMember since 2013
a bit of connections sprey while controller off and move the pitch fader up and down a few times usually sorts the problem out, not always if the slider is physically damaged but worth a try
geposted Sat 03 Feb 24 @ 11:20 am
