Topic: Will this setup work?
Hi I currently have an
Vestax analog mixer
traktor audio 6
Timecode vinyl
2 X turntables
I was thinking of adding a Akai LPD 8 mk2 usb midi controller pad to trigger loops/effects ect in virtual DJ. I like my mixer and just want to know if what I’m thinking will work. Can I map the Akai to virtual DJ? Is this something that is done often?
Also, what license is required? It’s home use only but if I purchase home plus “analog mixer” will the timecode vinyl still work under that license?
Thanks
geposted Thu 01 Feb 24 @ 1:16 am
Vestax analog mixer
traktor audio 6
Timecode vinyl
2 X turntables
Regarding your current setup it will indeed work, but traktor timecode is kind of famous for not being the best, so you may want to get a couple of serato vinyls (or indeed Virtual DJ vinys, but Serato vinyls are easier to get your hands on) and check if that improves your experience. That is a pretty cheap investment
Regarding adding a new hardware that will generally work, and is often done, but the LPD 8 is generally fiddly to work with. I would suggest a korg nanopad2 or maybe a Novation launchpad instead
Or if you want something that is specifically designed for the purpose, maybe a Pioneer DDJ-XP2, or one or two Reloop Neon
Not sure about that, someone else will know better
Timecode indeed requires a pro license.
