Hi,
I'm trying to change the effects assigned to the 4 FX buttons on my inpulse 500...the script is simple, so I'm sure I'm doing it properly but it just won't apply the new setting.
I can definitely apply one of the preassigned FX on other buttons, but can't change them to anything else (eg replace noise with phaser).
Can anyone advise if this should be possible?
Thanks
Rossi
Thanks
Rossi
geposted Sun 04 Feb 24 @ 8:24 am
geposted Mon 05 Feb 24 @ 10:51 pm
