Hello,
I have the Behringer xenyx302 USB audio interface and the matching Superlux HMC 660 X headset.
I also have a USB webcam with integrated microphone.
However, I can't create a live show on mixcloud via VirtualDJ with this setup. Either you can hear the music I'm playing but not my voice or vice versa, or I can't hear myself in the headphones or I can't hear the music... somehow it all doesn't fit together.
maybe someone has a similar setup and can help me with the settings?
Many thanks in advance
Christian
Christian
geposted Mon 12 Feb 24 @ 2:13 pm
As you're having problems with your audio config, please post a screengrab of your VirtualDJ audio config page.
You'll have to host the pic elsewhere and link to it, as you're not a licensed user.
geposted Mon 12 Feb 24 @ 2:17 pm
Thank you so much! Will do so tomorrow afternoon!
geposted Mon 12 Feb 24 @ 2:25 pm
Hope this is the correct screen..unfortunately it´s in German, but I think it might be easy to find out what is what.
This PHANTOM FADER seems to be my Behringer btw
https://i.postimg.cc/sxXhXyrw/VDJ1.jpg
geposted Tue 13 Feb 24 @ 4:45 pm
I'm assuming it's not VDJ's fault.
It seems to me it depends on the device or how you use it...
Since the screenshot is in German, I assume it's easier to understand in German :-)
Go to the linked page and read the first text in the reviews.
Maybe you'll think of something...
With the MischMasch device you can hardly give any help online.
Moderator ASIO4ALL is garbage - don't suggest it again
Here the link:
https://www.thomann.de/de/behringer_xenyx_302_usb.htm
Ich gehe von aus es liegt nicht an VDJ.
Wie mir scheint liegt es an dem Gerät oder wie Du es nutzt...
Da der screenshot ja auf Deutsch steht gehe ich von aus es ist in Deutsch auch einfacher zu verstehen :-)
Gehe mal auf verlinkte Seite und lese da bei den Rezensionen den 1. Text.
Evtl. fällt Dir dann etwas zu ein...
Bei dem MischMasch-Gerät kann man kaum Online Hilfestellung geben.
ASIO4ALL besorgen wäre ein guter Anfang.
(Link steht oben)
Here the link:
(Link steht oben)
geposted Wed 14 Feb 24 @ 9:00 pm
I tried everything but nothing seems to work...maybe my Behringer just can´t do it ?
Here is an image of my settings ( in englissh now ) and a link to the specs of my Behringer..maybe this helps ?
https://ibb.co/M70bJkm
https://www.behringer.com/product.html?modelCode=P0ADV
Thank you all so much
geposted Sat 17 Feb 24 @ 12:57 pm
i don't think the Behringer has enough lines on its own
by that i mean lines available on the USB interface
4 outputs are required to have master and headphones setup
geposted Sat 17 Feb 24 @ 3:46 pm
Agreed. Small cheap mixers like that would typically only have a single L/R stereo signal in/out via USB.
You could use it to send the mic signal to VDJ, and also to monitor back from VDJ to the headphones, but you can't send the master AND headphone signals to it.
If you're broadcasting then you don't actually need to send the master to the Behringer, as that would be broadcast from the VDJ mixer directly.
I'd suggest setting the audio config to send the master signal to your computer's onboard audio if you need to monitor via speakers.
geposted Sat 17 Feb 24 @ 4:02 pm
geposted Sat 17 Feb 24 @ 6:39 pm
your mistaken the USB portion only has 2 channels output
that mean 1 right and 1 left IE stereo
you require 4 channel output on USB to use it for master and headphones
the channels you mention are the devices totals not what is available via USB
geposted Sat 17 Feb 24 @ 7:52 pm
"the channels you mention are the devices totals not what is available via USB"
Yes, I've seen it now too.
Either 2 (left/right) to the PC or 2 (left/right) from the PC.
Not in both directions at the same time.
geposted Sat 17 Feb 24 @ 11:43 pm
Ok, I see and understand!
I had almost feared that it was due to my equipment.
I'll probably look around for other hardware that I can use to do what I want to do.
But thanks again to you both, you've really been a great help!!!
Stay healthy and have a nice Sunday!
geposted Sun 18 Feb 24 @ 12:28 pm
