Topic: Questions about buying VirtualDj
I have been trying to twist my head arround about buying VirtualDj. So if i understand this right If i buy VirtualDJ Home Plus for 119$ i can only use my Numark Mixtrack Platinum FX and not change my mixer becouse its locked to my Platinum FX (Right?) But the real question is, if i buy Home plus now for my mixer, can i still use this key and my mixer on a random pc? Becouse i have an old pc now witch i am using, but i am gonna upgrade to w new laptop this summer. I just wanna make sure i dont need to buy two key for VirtualDj just becouse of pc change :)
geposted Thu 29 Feb 24 @ 6:48 pm
Your licence is your login, the computer used doesn't matter.
A home plus for Numark Mixtrack Platinum FX will work on any machine you login with but only with a Platinum FX.
Yes the home is locked to one controller, but you can be logged in to any two PCs at the same time. Once you log in to a 3rd one the oldest connected will be logged out.
Ok thanks guys :) have a great day :)
