Hi
I may have done something Virtual DJ was not designed for in Virtual DJ i selected an .mp3 file and added a .png picture to it using 'Video Editor' (selecting 'all files' to be able to add the .png).
All worked fine.
I then added that .vdjedit file to a sample bank, again it works as I hoped playing the audio with the .png file appearing on the video screen.
However, if you 'edit' the sample in the sample sidelist and then save it (i.e edit the name of the sample), everything breaks and the sample no longer plays at all.
I thought you should know.
All worked fine.
geposted Tue 05 Mar 24 @ 12:47 am
Are you changing the name here?
I had some similar issues with that too. Link to my post
geposted Tue 05 Mar 24 @ 10:10 am
