Hi all,
I would like to make a little customization of the definination file of my old rusty Denon HC4500 device. Does anybody knows where i can find this file so i can change it? In my local devices map of virtual DJ there is only 1 file......controllers.dat (cant open this with notepad)
Most leds can be controlled with the mapper file, but in my case the cue button cannot be changed.
For instance i can not set this button to blink.
Greetings,
Marcel
Greetings,
Marcel
geposted Tue 05 Mar 24 @ 5:22 pm
The definitions are built in to the core program and can't be modified as far as I am aware.
https://www.virtualdj.com/wiki/Controller%20Developers.html
geposted Tue 05 Mar 24 @ 5:23 pm
The Denon HC-4500 ..... cue led is in the definition... with key: LED_CUE
It does not have any script in the default mapping, so need to find the unused keys, in the "Key" drop down menu.
(and depending if the controllers firmware allows, you can change mapping as you like to controll the cue's led)
geposted Tue 05 Mar 24 @ 5:36 pm
Both thanks!!
Indeed led_cue can be mapped. I didn`t see it in the standard list.
Greetings,
Marcel
Greetings,
Marcel
geposted Tue 05 Mar 24 @ 7:20 pm
