Topic: SOUD FX EFFECT BUTTON
I have the Hercules Impulse 500, I'm using the INP FX pad, the effect volume, it's the LOOP_ENCODER button, which does it, but I don't like this button, I want to use the AUX_FILTER, to control the effect volume, I used this function pad_page 'INP FX' ? var 'fxparam' ? effect_slider 1 & effect_slider 2 1 & effect_slider 3 1 : loop_double : loop_double , this new button is working, but the problem is that it only works on the deck with the most popular music, how can I do it so that I always use the same deck, the volume works of the two decks
geposted Sun 10 Mar 24 @ 1:51 am
