Topic: License code on controller no longer valid
Hi, after some years, I put out my old Hercules MK4 controller and installed the actual version of VirtualDJ. This new version with online connect will need an account from me, so I decided to use my google account for this.
I logged in here on this page and tried to enter my code from the controller.
Unfortunatly I get the message, that my code is no longer valid.
How could this be? I use a supported controller and have a license and this will not work?
How I get my controller to work without buying a new license?
Thanx for helping in this issue,
Thorsten
geposted Wed 13 Mar 24 @ 5:59 pm
If your controller came with VirtualDJ 7 LE, then the keycode is not valid for version 8.
Goto.. https://www.virtualdj.com/users/licenses.html , register your LE keycode there (in case you have not done already), then scroll down and expand the "Old discontinued products" to find your LE 7 and the download link.
If you need to use the current VirtualDJ version, you will need to buy a license
Thats my problem. When I goto the license page and enter my code, it says the code is not valid anymore and so I can't download any older V7 Version.
Hola, me ocurre el mismo problema, compré una MK4 con una licencia VIRTUAL DJ y tengo el numero de serie. Solo quiero continuar utilizándola, no quiero versiones nuevas, me pueden enviar enlace de descarga compatible con mi controladora por favor? (por favor, no me indiquen que tengo que comprar una licencia, ya lo hice en su momento)
