Topic: Beat Grid Effect instructions
Hi. Hope this is the right forum for this.
I've been playing with the beat grid effect. Are there any instructions for this?
I've noticed that each quarter notes on the grid cannot be turned off for some reason. Is that a glitch? All other steps on the grid can be turned on or off.
Also, wondering if there is anyway to only hear the steps on the grid...like maybe a wet/dry mix?
I've been trying to use it as a sort of 'trance gate' effect, to take a loop and make it into a percussive element while transitioning into the other deck. The beat grid effect is the closest thing I've found to a step sequencer in VDJ thus far.
Thanks, I hope my questions made sense.
geposted Tue 19 Mar 24 @ 6:15 pm
That's how it works, it's a position plugin, it has to play something on beat the following 3 quarter beats are optional position switches,
It has been like this since v8 release [10 years now] what you see is what you get.
if you want a trance gate use a vst.
geposted Thu 21 Mar 24 @ 5:17 pm
