Topic: Use Stems buttons pads to mute the instruments slowly
Hi! I trying to configure the pad buttons that I use for Stems. Now they can mute the Stems, but they mute it immediately. I like to make it to mute it slowly, lowering down the volume until its out. It's possible? If so what attributes I can use to do it in the mute_stem config?
geposted Thu 21 Mar 24 @ 9:58 pm
You wouldn't use mute_stem, you'd use a repeat_start script to lower the stem dial, then query if the dial is at zero, if so stop with repeat_stop
repeat_start scripts
geposted Thu 21 Mar 24 @ 10:10 pm
Thank you! I got it.
Using:
repeat_start "stemvol" 1000ms 10 & stem kick -5%
I can get a soft fade out from the Stem I want in 10 seconds.
I tryed to get the reverse effect using the var_equal option.
var_equal stem kick 50% ? repeat_start "stemvoldown" 1000ms 10 & stem kick -5% : repeat_start "stemvolup" 1000ms 10 & stem kick +5%
But I don't get it working, only get the volume down but don't made it up after.
So I made a Workaround using holding:
holding ? repeat_start "stemvolup" 1000ms 10 & stem kick +5% : repeat_start "stemvoldown" 1000ms 10 & stem kick -5%
So I can get it to mute and to normal volume when I want.
geposted Fri 22 Mar 24 @ 2:43 am
stem kick 0% ? repeat_start "stemvolup" 1000ms 10 & stem kick +5% : repeat_start "stemvoldown" 1000ms 10 & stem kick -5%
or maybe
stem kick 0.0 ? repeat_start stemvolup 200ms 50 & stem kick +0.01 & param_smaller stem kick 0.49 ? repeat_stop stemvolup : nothing : repeat_stop stemvolup & repeat_start stemvoldown 200ms -1 & stem kick -0.01 & stem kick 0.0 ? repeat_stop stemvoldown
geposted Fri 22 Mar 24 @ 2:48 am
The two ways works like a charm! Thank you very much!
geposted Fri 22 Mar 24 @ 6:59 pm
