I once saw a dj using tractor and he also had the virtual dj open to detect the controller. He told me: I only have the virtual DJ to detect the controller but as you are seeing I mix with tractor. Does anyone know how to do it please?
geposted Sun 24 Mar 24 @ 11:47 pm
If you want your controller to work, the only reliable solution is to mix with virtualdj
geposted Mon 25 Mar 24 @ 10:41 am[ selected best answer by Stephane Clavel on Mon 25 Mar 24 @ 10:42 am ]
Sounds like a problem for the traktor forums.
geposted Mon 25 Mar 24 @ 12:18 am
They told me the same thing: it's a problem so you should ask it on the virtualdj forum. Jaja
geposted Mon 25 Mar 24 @ 1:31 am
No, it's a traktor problem, you want to dj with traktor that's where you ask.
Why you'd need vdj as a middle man, doesn't really make sense.
geposted Mon 25 Mar 24 @ 1:47 am
I see he's calling himself Eric over there, and despite people telling him it's not possible, he continues to claim it's true....................because he's seen it with his own eyes.
I guess the Statue of Liberty really did vanish in 1983 then :-)
geposted Mon 25 Mar 24 @ 8:06 am
News just in............apparently it could be something to do with sysex messages sent to certain controllers (i.e. Numark) to disable a demo mode that they default to after a certain time has elapsed.
He had been saying that it was an FLX4 being used, so I guess it wasn't.
Presumably controllers would still need mapping in Traktor though.
He also seems to believe that this "trick" will work for all controllers....
geposted Mon 25 Mar 24 @ 10:05 am
Selected as best answer geposted Mon 25 Mar 24 @ 10:41 am
