I use laptop with the pro skin - it is not possible to see what is written on pads because the fonts are too small. Also please fix the issue on ddj 800 - not possible to choose hotcues 9-18 because the arrows to select page on controller don't work with hotcues.
if there was an option to switch between elapsed time and remain time on jog wheel by pressing a button on controller that would be very useful
geposted Mon 25 Mar 24 @ 6:22 am
1. That sounds like something you need to fix on your laptop screen resolution
2. Not that is not what the parameter buttons are for. But you can maybe remap hotcues an a new pad page maybe combined with using 16 pads mode
3. Yes, I think you can map that on your controller using a simple SETTING toggle script:
setting 'DDJ800-timeDisplay'
... I can't test it though
geposted Mon 25 Mar 24 @ 9:48 am
