I did this weekend the new updates but I can't make a record anymore.... Can somebody help me please?
geposted Tue 02 Apr 24 @ 11:24 am
What error message do you get?
geposted Tue 02 Apr 24 @ 12:10 pm
no record source configured. Please select a recordsource in audio config....
Now I have made records yesterday with no changes in the config, but today nothing anymore
geposted Tue 02 Apr 24 @ 12:14 pm
same Problem I open my DDZ2 Setting utility turn 9/10 on rec ou/No mic then back to rec out to work,I have not tried rec on my other controllers to see if still working.
geposted Tue 02 Apr 24 @ 12:27 pm
Can you guys post screenshots of your VirtualDJ Audio Setups ?
geposted Tue 02 Apr 24 @ 12:43 pm
.png)
.png)
These are the screenshots....
geposted Tue 02 Apr 24 @ 2:58 pm
Filename should actually be fullpath
example case will save to my desktop with file name of recording date_myMix
C:\Users\user\Desktop\%date_myMix.mp3
geposted Tue 02 Apr 24 @ 3:04 pm
I believe it has to do with the path of the recording file.
Try to click on the [...] dots next to the Filename in the RECORD panel, navigate to an existing folder and then add the name at the end.
As far as i can see in your screenshot, there is no Drive:] Path, just a filename.
1) Next to Record Source, click Configure Loopback Audio Source
2) It will take you to the Audio tab, go back to Record
3) Hit record
4) start your first track
5) go back to Settings, Audio
6) X out the forced input with the record drop down then Apply (audio output will stop for a second)
From there, it should be recording just fine. I didn't have this problem until the most recent update. I hope they fix it soon because it's tedious.
geposted Fri 18 Apr 25 @ 4:51 pm
3) Hit record
3) Hit record
I've just tested with the latest version and an old Pioneer DDJ-400, and that works fine out of the box
I've written a bit more in your other post on this
geposted Fri 18 Apr 25 @ 6:10 pm
same problem after update my recording quality is gone bad...very low sound with no bass
geposted Mon 19 May 25 @ 1:08 pm
same here..theres some issue with the new updates.. virtual dj please look into this asap
geposted Mon 19 May 25 @ 1:09 pm
