This is driving me crazy since re-installing VDJ there os no option to create a new playlist in "Local Music" I'm using the most up to date Vanced skin when changing skins there still is no option to create a new playlist. When I click the
"+" button on the left side of the files all I get is the option to give current playlists a new icon.
geposted Sat 06 Apr 24 @ 9:25 am
The changes are covered in the manual. There have also been several posts about the changes on the forum.
geposted Sat 06 Apr 24 @ 1:42 pm
thanks for you're reply, what manual?. how do we make playlists now?
geposted Sat 06 Apr 24 @ 2:07 pm
sorry for the double post can't see how to delete the other one
geposted Sat 06 Apr 24 @ 2:08 pm
Cuepoint777 wrote :
what manual?
The VirtualDJ manual. What else would it be?
geposted Sat 06 Apr 24 @ 2:24 pm
playlists are now mostly supposed to be in the MyLists folder.
To create a new one, just click on the text "click here to create a list" that is shown instead of files when you select the MyLists folder. (or right-click and select "add list").
If you really want to keep your lists under local music, you can easily just drag and drop them from MyLists to LocalMusic
geposted Sat 06 Apr 24 @ 2:50 pm
THANKS, X
geposted Sat 06 Apr 24 @ 4:58 pm
