Hi Guys,
I'm currently having issues with trying to make my Numark FX work on windows 11 .
I was having some issues, noticing if I used a cheap soundcard, the headphones function would work occasionally and then spontaneously cutting off. Rebooting it seemed to help. I would use the the onboard soundcard as headphones and the soundcard as master.
I have a gig coming up and have updated to a better soundcard: M Audio Solo. (yeah, on a budget) and now cant get the headphones function working at all.
Any Help muchly appreciated. (using the onboard Nurmark FX soundcard output isn't an option)
Many thanks in advance
geposted Tue 09 Apr 24 @ 9:46 pm
Mixtrack Pro FX? Platinum FX? NS4 FX?
What are the issues?
What were they?
Why not?
What were they?
Why not?
geposted Wed 10 Apr 24 @ 8:23 am
