Using build 9093, I am having issues deleting Filter Folders. If I attempt to delete a Filter Folder under a Virtual Folder where all files are located on an external drive, it will disappear in VDJ but once you collapse and expand the Virtual Folder it appears again. The actual file on the drive doesn't get deleted. The only way to actually delete the filter is to delete the file from finder.
geposted Mon 15 Apr 24 @ 12:32 am
