when I create a new fliter folder, and I assign a few track with the filter. when I go back to that newly created filter folder the I does not populate every song. you guys need to fix these bugs ASAP. these things usually happens when you update the software. you guys need to be more professional, we are paying Pro Version to get quality service not bugs and glitched. Since last year my supposedly "CUE" button is spelled "CUH" C'mon. Seriously considering SERATO. FIX THESE ISSUES!!!!
geposted Mon 15 Apr 24 @ 4:58 pm
you changed cue mode to cue hold
geposted Mon 15 Apr 24 @ 6:05 pm
yes it does change when you put it on cue, Thank you. However what about some of the song you'vee given a label but won't show in newly created filter folder
geposted Mon 15 Apr 24 @ 6:19 pm
[quote=user20650290]when I create a new fliter folder, and I assign a few track with the filter. when I go back to that newly created filter folder the I does not populate every song. you guys need to fix these bugs ASAP./quote]
geposted Mon 15 Apr 24 @ 7:17 pm
I figure out the solution to the files not showing up in the filter folder. You need to add the new songs to the search DB.
geposted Wed 17 Apr 24 @ 7:41 am
