I have 16,619 files in the delete from search filter folder. These were files that I had on a previous computer that used the C Drive to store these files. On a new computer the C Drive was not large enough to store the files, so I Used the D Drive. I then had duplicates of all my files, so I removed all the C Drive files from the search. That worked fine but I would like to get rid of all the files that reside in that delete from search filter folder. When I go to file operations and click delete nothing happens, they remain. I tried moving them to another folder, but that is unsuccessful. Is there a way to remove these files?
geposted Wed 17 Apr 24 @ 6:32 pm
clean your Database.
geposted Wed 17 Apr 24 @ 8:50 pm
How do I clean the database?
geposted Wed 17 Apr 24 @ 10:25 pm
Ok I found it. I now have only 14 files left. Thanks for you help!
geposted Wed 17 Apr 24 @ 10:29 pm
