The below action code starts and stops the kick drum:
sampler_bank 3 &
sampler_play_stop 1
The below button code with back ticks displays the word 'Instrument' on the button
`get_sampler_bank`
How can I instead have it display the name of the instrument like 'Kick' and have the button show it's active?
sampler_bank 3 &
sampler_play_stop 1
`get_sampler_bank`
geposted Sat 20 Apr 24 @ 10:08 pm
Does get_sample_name not do the job?
geposted Sat 20 Apr 24 @ 10:35 pm
Great that's half of it. It doesn't show the status of the button though.
geposted Sat 20 Apr 24 @ 11:03 pm
sampler_bank 3 & sampler_play_stop 1 & sampler_play 1 ? on : off
geposted Sat 20 Apr 24 @ 11:44 pm
Interesting, I tried that full command in back ticks but that didn't do the trick and just displays the text "on" in the custom button.
If I leave
In the action code
and put
in the button name, the actual button toggles between the text "on" and the text "?"
Just to be clear this is for the custom buttons displayed on the laptop screen in VDJ.
Thanks
geposted Sun 21 Apr 24 @ 12:05 am
what I posted was the button action, not the name.
geposted Sun 21 Apr 24 @ 12:21 am
Yep tried that and this in the action code with no luck:
sampler_bank 3 & sampler_play_stop 1 & sampler_play 1 ? color "red": color "green"
Closer when I use the following code back ticked in the custom name which shows the text "Red" or "Green" depending on state but it doesn't change the color of the button
sampler_play on ? color "Green" : color "Red"
This is all entered into the virtual DJ embedded Button Editor. Not using the template editor for this setup.
Is there more documentation than the Wiki, sorry maybe I am missing something.
geposted Sun 21 Apr 24 @ 12:56 am
custom buttons don't do colour, they do on|off
geposted Sun 21 Apr 24 @ 1:38 am
Hmmm, OK let's say I have the following button in my custom template:
<button deck="master" class="myPopupWin" action="custom_button 68" textaction="custom_button_name 68" rightclick="custom_button_edit 68" textcolor="textoff3" query="sampler_play 1 ? on : off">
<pos x="816" y="5"/>
<size width="100" height="35"/>
<up x="5" y="45"/>
<selected x="115" y="45"/>
<over x="225" y="45"/>
<off color="red" border_size="1" border="gray"/>
<on color="green" border_size="1" border="white"/>
<text size="14" font="Arial" weight="bold" align="center" color="#ffc8c8c8"/>
<textselected size="14" font="Arial" weight="bold" align="center" color="#ffffffff" text="[TEXT]"/>
<textover size="12" font="Arial" weight="normal" align="center" color="#ffFFFF00" />
</button>
Adding the query to the button doesn't seem to do the trick either unless I'm still mangling the use of the query.
Update: but ? blink : off does work
geposted Sun 21 Apr 24 @ 2:29 am
OK thanks @locodog & @groovindj
For now I created a custom button in a window popup via a new skin that just shows when I enable the kick drum and allowing toggling.
@locodog the query worked in the template but I couldn't use the on tag but the selected tag worked:
This is fine for the most part but curious if I can add anything to the query that can determine wh
<button deck="master" class="toolbarX" action="custom_button 68" textaction="custom_button_name 68" rightclick="custom_button_edit 68" textcolor="yellow" query="(param_equal get_sampler_bank_id 3 && sampler_play 1) ? blink : off">
<up x="5" y="45" radius="5" color="#550000" gradient="vertical" color2="#330000" border_size="5" border="#CCDDCC"/>
<selected x="115" y="45" radius="5" color="#009900" gradient="vertical" color2="#005500" border_size="5" border="#CCDDCC"/>
<over x="225" y="45" color="grey" radius="5" gradient="vertical" color2="grey" border_size="5" border="#CCDDCC"/>
<off color="black" border_size="5" border="#393939" gradient="vertical" color2="grey"/>
<textselected size="14" font="Arial" weight="bold" align="center" text="[TEXT]"/>
</button>
geposted Sun 21 Apr 24 @ 4:57 pm
Update:
This doesn't work perfectly. It will blink only when the kick drum f/x is running and the instrument bank is loaded. There are scenarios where you might start a kick drum and then load another f/x which will stop the display of the blinking of the button.
If I find a solution I'll post it.
geposted Sun 21 Apr 24 @ 6:25 pm
just call the sample by name then
sampler_play_stop "135 (1)"
geposted Sun 21 Apr 24 @ 6:42 pm
@Locodog, you're the master!
(sampler_play_stop 'Kick Hard') ? blink : off"
geposted Mon 22 Apr 24 @ 1:31 am
