something that may be useless to manybut for me it would be useful and I will explain why... I'm working with playlist now my lists... each list is a genre of songs eg RNBbut each RNB list has songs with subcategories inside where I have them by group... I would like these groups to be able to distinguish them with a line like in the photo so that I can distinguish each group as quickly as possible.
the photo is downloaded from Google..
![](/img/404456/17796/skin-default.jpg)
geposted Mon 22 Apr 24 @ 9:55 pm
Just create a dummy empty mp3 file, and edit it's tag to something like
Artist="------------- GRP CHANGE ---------------"
Title="------------- GRP CHANGE ---------------"
Then drag this dummy file as many times as you wish inside your list and place it accordinbly.
You can also assign a color to it, or use a color rule to color it for you automatically
geposted Tue 23 Apr 24 @ 1:15 pm
clever I hadn't thought of that ... but if you can help me more how to do it exactly ... it will be a normal song but ... I will rename it?
to put hyphens in the name, surname and title; I will give it a try! thanks smart!
geposted Tue 23 Apr 24 @ 1:21 pm
problem.... nice idea but... when I load the list in automix this song will also play
![](/img/404497/33284/Messenger_creation_a68ea6f4-8345-455f-a4a0-626137249700.jpg)
geposted Tue 23 Apr 24 @ 1:35 pm
Well, I guess you can't have everything at the same time :P
I mean, if the list is going to be played by automix, what's the reason to have a visual split between "subgroups" ?
Anyway, try to make the file very short, like 1 sec. Then perhaps automix will ignore it.
geposted Tue 23 Apr 24 @ 1:51 pm
there are cases where I play them live and sometimes with automix....
never mind it was a good idea that didn't catch on! 😁
geposted Tue 23 Apr 24 @ 2:33 pm
i was asking for the same kind of thing here
https://www.virtualdj.com/forums/246950/Wishes_and_new_features/advanced___DJ_set_preparation__window.html
geposted Sat 27 Apr 24 @ 6:12 pm
I'm glad they have another one, this wish of mine 😊😊😊
geposted Sat 27 Apr 24 @ 6:45 pm
Until the wish is impletemented in VDJ.. one could continue along the same thinking of Phantom DJ's workaround, but modify a "Missing Track", instead of a working track.
(a missing track will NOT be played by automix.. and will be skipped, as if it was not in the list)
OR
one could make the track you have already modified... Missing,
by deleting/renaming the track from within the OS. (again so it will be ignored in automix)
Summary:
Create your divider with a Missing track.
OR
Summary:
geposted Sat 27 Apr 24 @ 7:27 pm
OR
Clever!
geposted Sat 27 Apr 24 @ 10:16 pm
OR
Summary:
OR
Summary:
LOL I had created a .03 second silent Wav file which did the job, but it is true that when doing an automix, it does prevent the files from overlapping
making into a missing file does overcome that although I dont think I really need this in my every day use
im not sure how to deal with that when im restoring my database and it asks me if i want to remove missing files though..i presume it will remove that file then too.
![](/img/404766/43801/U nt itle d-1.jpg)
geposted Sat 27 Apr 24 @ 11:36 pm
I put an mp3 file where I named it with dashes " ------ " and after i put it in the lists and categories i wanted... i moved the file to another location like the other kid said way above... and it did the trick.. it works fine even in automix... it skips it no problem or some gap... makes the change to the next song immediate.
great help... changed the perspective on my lists
it would be perfect if he makes our wish come true 👏👏🙏🙏👼👼✝️✝️
geposted Sun 28 Apr 24 @ 12:56 pm
