Anyone has this problem, the VU meter on the PRO skin is not synch with the music output, its half beat off
geposted Sat 27 Apr 24 @ 2:41 pm
What sound interface do you use ?
If the VU is not synced, then everything else on screen should not be synced as well.
And that means that your audio interface is configured with WAAAAAY too much latency
geposted Mon 29 Apr 24 @ 11:00 am
Display as an offset from the audio, i tryed changing Asio latency but no change, i have no clue what is the solution for this problem.
geposted Tue 07 May 24 @ 1:02 am
