Topic: CUE points starting track instead of pausing at point
thor_jHome userMember since 2021
Hi there,
Am new to these forums.
Recently transitioned from Virtual DJ IOS to Windows Virtual DJ LE which came with my Pioneer DDJ-WeGo3.
Learning the ropes on Windows, but for some reason when I set a CUE point in a track and press the corresponding CUE number the track starts from that CUE point instead of taking me to that point in the song. Hope it makes sense.
In the IOS version set CUE points did not start the song from that point when pressed, my PLAY button did that trick and was kind of hoping I could get the same functionality on Windows version.
Anyone have a solution?
Thank you in advance.
/Thor
geposted Mon 29 Apr 24 @ 7:10 pm
Change the "hotcueMode" setting to "stutter" instead of "play"
geposted Tue 30 Apr 24 @ 7:16 am
Thank you for your reply, appreciate it.
However when looking at the mapping I can't seem to find the HotCueMode so I can change it.
I have attached a link to an image of my controller mapping if that helps, but looked it over, but no HotCueMode or Stutter.
https://ibb.co/X4GMVsY
Any other tips?
/Thor
geposted Tue 30 Apr 24 @ 5:34 pm
it's a setting, not a mapping.
geposted Tue 30 Apr 24 @ 5:36 pm
Great - thank you, solved :-)
Now I just found out that BPMs are no longer shown in LE track browser rendering the use of VirtualDJ more or less useless in my eyes.
But thanks for sorting this, much appreciated.
/Thor
geposted Wed 01 May 24 @ 3:31 pm
