There seems to be a bug when operating automix as follows.
1. Open automix
2. Close automix without doing anything
3. open automix again
In this case, the play button of automix does not work (it can be played by reopening automix again).
Windows10 / RTX2060 / Roland UA-M10
1. Open automix
geposted Fri 03 May 24 @ 4:26 pm
A mi tambien me ocurre algo parecido. Desde ayer 18/05. Automix no funciona bien. Cargo los temas en la lista le doy al boton y carga y reproduce una cancion en la platina pero no carga la siguiente y cuando acaba la canción, no continua la lista. Ademas el botoncito no se queda fijo en azul, es como que se desactiva solo. Alguine puede ayudar?
Ultima version de Virtual dj
Macbook Pro M2 Max
MacOs Sonoma
Denon MC 4000
Macbook Pro M2 Max
MacOs Sonoma
Denon MC 4000
geposted Sun 19 May 24 @ 9:44 am
Sorry, "automix" is a misspelling of "automix editor"
1. Open automix
1. Open automix
geposted Mon 20 May 24 @ 3:28 am
Seems to work fine here.
This also happens when you just open VDJ and don't do anything else?
geposted Tue 21 May 24 @ 8:02 am
Hi Adion, sorry for the late response.
I checked again with b8176 and could not reproduce this problem.
(If I reproduce it again, I will write here)
geposted Thu 23 May 24 @ 2:24 pm
Hi,
I was able to reproduce the automix bug on b8553.
(It appears that procedure 2. is the cause)
1. open automix
2. press the play button and close it while it is still playing
3. When automix is opened again, the play button is still in “stop” position and cannot play.
I checked on 3 different PC and all had the same problem.
(※I also sent a movie to support)
Windows10 / RTX2060 & RTX2070 / Roland UA-M10
1. open automix
geposted Thu 01 May 25 @ 3:50 pm
What do you mean by closing the play button?
Are you using the play pause buttons on the deck?
geposted Thu 01 May 25 @ 3:53 pm
Here's youtube movie
https://youtu.be/56_f796GRcA
geposted Thu 01 May 25 @ 3:57 pm
Would have been helpful if you had mentioned that you were talking about the aitomix editor, and not automix itself lol
geposted Thu 01 May 25 @ 4:06 pm
I am very sorry for any confusion..
geposted Thu 01 May 25 @ 4:09 pm
No problem, will be fixed in next update
geposted Fri 02 May 25 @ 7:04 am
He did, last year :-)
geposted Fri 02 May 25 @ 10:31 am
Ah yes, but the step of playing without stopping before closing the editor was missing which is probably why I couldn't reproduce at the time
geposted Fri 02 May 25 @ 1:06 pm
Checked on b8600 and working perfectly.
Thanks Adion!
Thanks Adion!
geposted Tue 13 May 25 @ 9:23 am
