Topic: automix bug?
There seems to be a bug when operating automix as follows.
1. Open automix
2. Close automix without doing anything
3. open automix again
In this case, the play button of automix does not work (it can be played by reopening automix again).
Windows10 / RTX2060 / Roland UA-M10
geposted Fri 03 May 24 @ 4:26 pm
A mi tambien me ocurre algo parecido. Desde ayer 18/05. Automix no funciona bien. Cargo los temas en la lista le doy al boton y carga y reproduce una cancion en la platina pero no carga la siguiente y cuando acaba la canción, no continua la lista. Ademas el botoncito no se queda fijo en azul, es como que se desactiva solo. Alguine puede ayudar?
Ultima version de Virtual dj
Macbook Pro M2 Max
MacOs Sonoma
Denon MC 4000
geposted Sun 19 May 24 @ 9:44 am
Sorry, "automix" is a misspelling of "automix editor"
1. Open automix
geposted Mon 20 May 24 @ 3:28 am
Seems to work fine here.
This also happens when you just open VDJ and don't do anything else?
geposted Tue 21 May 24 @ 8:02 am
Hi Adion, sorry for the late response.
I checked again with b8176 and could not reproduce this problem.
(If I reproduce it again, I will write here)
geposted Thu 23 May 24 @ 2:24 pm
