Forum: VirtualDJ Skins
Topic: Traktor S5 skin
Hi everyone!
I've been using VDJ since 2016, but I've never made a skin. I recently bought a new controller and thought I'd switch to Traktor, but I really kinda hate it and miss Virtual DJ. I'm wondering if anyone can point me in the direction of making a skin? I've installed the skin for the S8, but there's not an easy way to modify it that I can see.
TIA,
Adrienne
geposted Sat 04 May 24 @ 1:29 pm
It's a tricky one. Typically the screens do not work in other software, but someone seems to have figured it out for the S8. <3
S5 isn't supported hardware and there isn't a mapping & definition plugin available.
I think you're out of luck on this one.
It detects the board. There just isn't a skin.
Well, it detects it and knows what it is. It doesn't work, if I recall. You may be right. I'll be sad if that's the case!!
It probably detects as simple midi [input only, no LEDs out].
