I was wondering if anyone could help me solve an issue I seem to be having once I record a mix?
Once the tracks are mixed the cue points automatically appear on the waveform display panel which is fine but once I close Virtual DJ down and say try to reload the recorded track later on all the cue points and track names seem to disappear.
Any help or guidence with this would be much appreciated as to how to solve this issue.
Thanks a lot.
Thanks a lot.
geposted Fri 10 May 24 @ 5:19 am
The cues should not dissapear unless you moved or renamed the recorded file outside VirtualDJ.
geposted Fri 10 May 24 @ 10:44 am
Hi
Thanks for your reply
geposted Fri 10 May 24 @ 2:46 pm
